LareNurminen wrote: Hi,
I have had issues with hot starting on my -79 and -82 bikes. One idea that has been bounced around and has logic to it is:
Our carbs feed fuel due to the vacuum created by the pistons.
If the vacuum is not created, the fuel will not flow.
Therefore, having the idle adjustment screw set too high prevents the creation of sufficient vacuum and therefore starting.
When you start the bike cold, you use choke = add fuel to the system. When starting hot, you do not use choke = no start.
As written in the earlier comments, bump starting a bike which refuses to start hot works every time.
I have adjusted the idle screw to minimum to gain maximum vacuum.
I believe the hot starting problems are due to the insufficient vacuum, battery voltage going low due to starting and causing weaker spark.
Lauri
I'd like to respectfully challenge this statement.
This particular carburetor has 3 fuel delivery circuits, the Main circuit, the Idle circuit and the choke circuit.
The main circuit feeds fuel on or above the 2000 rpm range. Reason being as the butterfly valves open air being drawn through the venturi in the carb causes a low pressure area near the main jet which is also the location of the port which takes that vacuum and applies it to the diaphragm raising the carb piston which then meters the fuel through the carb.
the choke circuit is in fact a miniature carb within the carb with a jet that is very rich compared to the 14 to 1 ratio of the main jet circuit. When you open the choke circuit you're supplying air not through the main venturi like most automotive carbs but through a separate port.
The idle circuit is also a carb within a carb. It gets air supplied via a port in the front of the carb and draws fuel in as the air passes the idle circuit jet and this also is unlike the setup in an automotive style carb. it also is jetted rich compared to the main circuit @ 14:1 ratio.
Depending on how you've set up your butterfly plates (more open or less) will affect how far open you've set your idle air bleed screws. By design, Kawasaki has suggested that the throttle butterflies be set at 1-1/2 turns open from fully closed to set the baseline position of the butterflies. Adjusting the air bleeds after that point will richen or lean out the mixture and also affect marginally the idle rpm.
Bottom line, when starting the Kaws you shouldn't be opening the throttle at all which would apply a high vacuum to the idle circuit and or the choke circuit if it's been opened. There will not be any vacuum inside the main body of the carb at all since the butterflies are virtually closed.
