fuel issue 9 years 1 month ago #6485
  • trikebldr
  • trikebldr's Avatar
  • Thank you received: 38
Lucien-Harpress wrote: Gotta agree with doing all you can to avoid hydrolock.
Results aren't pretty.
That's just painful to look at, Lucien!
fuel issue 9 years 1 month ago #6486
  • Lucien-Harpress
  • Lucien-Harpress's Avatar
  • Thank you received: 108
Not as painful as my list of receipts.....
fuel issue 9 years 1 month ago #6487
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
  • Thank you received: 274
Hi Paul,
Please read this thread:
www.kz1300.com/index.php/forum/carburato...a-common-z13-gremlin
It's not that the floats are something that you could ever repair. They're made of plastic foam. I believe that alcohol in some fuels penetrates the foam and makes the floats progressively heavier.
Check out some of Scotch's threads on "Brass Floats".
Regards
fuel issue 9 years 1 month ago #6493
  • Thank you received: 831
Just to clarify: You can not shake an OEM float to determine if it has leaked. It is a solid piece which only absorbs fuel. Riding the bike may not necessarily free-up a "stuck" float.
Carefully remove the needle-valve body and determine if a piece of debris is stuck in the body orifice - preventing the needle valve from shutting off the fuel flow. Use a magnifying glass.
"The smallest piece of anything will cause flooding". A Quality fuel filter is essential !
Check the "o-ring" on the float needle-valve body. If the body pulls out easily with little or no resistance - the "o-ring" needs replacing. Check the needle retaining spring-clip. After market needle-valves are known to have their spring-clip interfere with the float. Check the tiny steel pin in the needle-valve (it makes contact with the float-tab). It is spring-loaded and must return to full extension when released and must be "free" to do so, with no indication it's movement is impeded or rough.
If these details check-out satisfactorily then re-evaluate the "wet-level" ON THE BENCH and adjust accordingly. A continued flooding issue usually indicates the potential need to replace the floats.
Last edit: by scotch.
Time to create page: 0.140 seconds
